I know
what's the radiator feel like? warm/cold/roasting?
that or the rad is blocked & the only cooling that's being done is through the heat exchanger in the cabin
when mine was over heating it burst 3 expansion tanks and it turned out to be the water pump buggered.
. idiots!! They thought it was the head gasket, but I dont think so. I reckon I might have the same problem with the hole in the thermostat housing. Is this hole in the little plastic bit in the middle of the hose going to the thermostat housing? Is this hole in the little plastic bit in the middle of the hose going to the thermostat housing?
Anyway, no thermostat is not a good idea. My car is now running pretty crap for the first 5 mins or so after start up. Heats up only in heavy traffic where Im not moving much but is cold all the rest of the time!
i just unscrewed the 2 small screwbolts that hold the thermo housing on and replaced the stat then bolted it up n toped the coolant up.i didnt get any airlocks but i might of just been lucky.
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Sorry to bump this thread up, but I just want to say that having replaced the thermostat housing cover thing, my ibiza is working perfectly WITH a thermostat. NO overheating and NO staying cold!!
I still cant beleive it took me all this time to fix it though. I went through 3 thermostats and about 15 litres of coolant just to find out that all you need to do is replace a small plastic thing!![]()
