I got my car remapped around 20000 miles ago and its been slipping on/off now for around the last 5-6000miles
It would only do it though in 5th/6th gear below 3500 rpm. If i got caught below 3500rpm, i would either part throttle it until above 3500rpm or change down into 5th/4th.
I had the clutch fitted yesterday at JBS for £220 which i thought was a good price. I supplied clutch.
Standard flywheel is £550-£600. No idea how much a lightened flywheel is
JBS offer a swapping system on your flywheel if it is knackered! He'll replace it for another used but skimmed flywheel for around £150. He'll then send your flywheel to be skimmed and sell it onto the next customer and so on and on. Thought that was pretty good really seeing as a new 1 costs 4 times that amount! Luckily though mines was fine!
Another VAG based tuner quoted me £350 fitting and was adamant i needed a new flywheel at £550. He told me my flywheel would definitely be damaged and need replacing if the clutch was slipping! Just pays to shop around lol
I fitted a sachs paddle clutch with an uprated 430lbft pressure plate. No real difference in pedal feel either which was good!
No more slipping and allows me to progress a bit further with BT conversion
cheers for that mitchy!
as said tho, hopefully i wont need to change my clutch whilst i have the car!
otherwise i will also be goin for a sachs performance one, as a friend of mine works there!
