so, you suggest me to use GT2256v on my 2.0 tdi 140hp? and i can get 250hp? and there wouldn't be turbo-hole below 3k rpm? any other modifications, like manifold, exhaust or injectors? now i have stock turbo and i have 195hp and 420nm only with remap and k&n panel filter
ok, but can you expain what is cam? tnx
is there any news? i'm thinking to install gt2052v... what you think about that and how much power should i expect?
My car is off to Allards at the end of the month for the bigger turbo modification plus a few other things like an oil cooler,another gauge,stronger clutch and SMF,sump guard,front wheel arches getting cut and enlarged,bigger 8 pot 365mm brakes,custom braided brake hoses,H+R front and rear ARB`s,changing the NOS so that i have four nozzles drilled into the inlet manifold spraying straight at the inlet valves plus a few more tweaks
@jlovrek Best PM trqster about the turbo and what peak power it can make as he knows a lot more about turbos then me.
