[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 060
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
Did my TB alignment today, using these instructions via vag-com, did it a couple of times to be sure every thing was ok,
I got some variation's in read outs as follows
______
first time:
Throttle sensor 1 | Throttle sensor 2
14.5% ------------| 85.1- 85.2% (flickering between)
Second Time
14.1% ------------| 85.5%
Does anyone know why the variance occurred, and what/why it is please.
Car seems to rev a little better afterwards, just about to go out for a spin to see if theres any difference in performance.
Also I had some fault codes desplaying - Which i've cleared
which were:
Power supply terminal 30 - Voltage too low
P1602-35-10 --- Intermittant
Can any one clear up what these figure's represent please..
