jib has been rumbled by the mk2 masses lol
I like bodykitsNothing to be ashamed of
Is this Inferi Black?
Yes! Another Ibiza saved from the depths of hell! Good work fella, it's all worth it in the end.
My strut brace doesn't touch the brake reservoir cap or come anywhere near the coolant reservoir cap. Although, it does get in the way of the brake fluid cap I can still refill it.
isnt that the one that shakira designed? i doubt its infiri black mate,
. If its an extremely high tensile bolt I'm not sure. Can you fit two nuts on it? Thats always a good trick!Can i have a link to where you got it? How hard was it to fit it yourself?
Thanks.
The best way I'd say is to buy a bolt removing kit from machine mart. They're like little drill heads that you drill/screw in on a dye, once they've dug in they start to screw the bolt out.
My friend has some I've used. If its an extremely high tensile bolt I'm not sure. Can you fit two nuts on it? Thats always a good trick!
