DPJ's GTRS Eliminator Install and Development
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
hope its all worth it
fingers crossed for you
Thanks Bill. :)
Two questions for you please......
My RamAir - is exactly the same as one for an LCR - except the LC kit has a reducer ring for the MAF? (Mine fits the S3 Maf housing ok without the ring)
Does the ABS body (the black cylinder that faces towards the turbo) get hot? The reason I ask is that the rubber on the ATP tip touches it).
simch
Newbie
Apr 12, 2004
33
Did you repair your intake with Plumbers mate? Thats a soft non setting putty..??
Surely you used something that sets ddin't you? A nice chunk of plumbers mate wont do your turbo much kop at 100krpm! !
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
:D
Plumbers Mait is a brand name. Although I do have a tub of the soft, putty like stuff, I used the repair stuff that sets hard as metal. It's handy, it will even set where it's wet. I made a permanent repair on an immersion cylinder a couple of years ago that would have cost £££ to replace otherwise.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Monday 25/06/07
Ok, I'm up and ready for action...
wild willy
2,323
Wales
:cop: oh no, looks like DPJ is at the more delicate stage of his tuning today.
Personally i'd stick with the dremel. :headhurt:
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
lunch time update? c'mon dave no time for sandwiches, get typing!
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Quick cuppa then :D
It's hell out there! It's pissing it down and the wind keeps blowing the ****ing pergola away. :rolleyes:
ATP manifold back in and torqued up. Just torquing the turbo to manifold and turbo to DP fixings.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Thanks Bill. :)
yes same as you say aside from reducer.
ABS should not run hot no - touchy things tend to rub thru however..
