what FMIC are you going with? are you planning on making the pipe work go beside the battery?
I decided this morning that I'm going to grind a few mm off the bottom of the turbo compressor inlet just below the bottom bolt hole, rather than take a chunk off the diff housing. The lip on the diff housing must give it some strengthening.
Should've clocked the compressor![]()
Nah - outlet would point at an odd angle and the oil outlet wouldn't be at its lowest point.![]()
So it'll be a runner this weekend then dave?
