oh when you say mdf ring...is this a ring going round the entire circumferance of the speaker, or 4 small rings that each nut& bolt go thro?
hi Phil, they should go around the entire circumference.
hi Ric. Do you mount the mdf with the same bolts as the speakers? Are the whole perfectly aligned with those of the doors? I bought some bolts plus some wood screws for the speaker. Will install everything next weekend most likely. btw, what size mdf did you use?
I got my Focals today!!They look great, although there is some rust on the back, but nothing that won't come off. I do think that I will end up having to stick the crossovers in the back, cause wow are they heavy! Probably velcro them to the back of the seats.
