Right, finally got round to fitting the Nomad pillar & gauges this morning.
After much p***ing about with dash & firewall got everything in.
Have got both gauges lit up ok, but Oil temp is not registering anything .. i'm going to check all the wiring over the wkend, an then order a new sender on Monday if I don't have any luck.
Boost Gauge is fine, altho I want to check some figures with everyone.
Full throttle in 2nd gear is only showing about 5psi, is this right. I had a look round and couldn't find a mention of what the std boost should be on an LC...can someone confirm please.
The other thing is that I showing -30psi when I'm just cruising up the road (little or no throttle) is that right?
Other than those hicup's i'm happy with the install, and once i'd finished with the fiddley bits it was plain sailing especially with Moff's (Rob) wiring guide).
I'll get some pic's up once i've got it all working!
Cheers in advance.
Cheers in advance.
