My next simple mod..
micky 32
630
Longford, Ireland
Visit site
Iv'e ordered a BMC panel filter. Also i have had a rummage in the garage at home and came across and old vaccum cleaner. So im going to drill a hole into the airbox and add the vacuum cleaner hose as an extra air intake;) It should help to breathe a little better.
muddyboots
Still hanging around
Oct 16, 2002
5,739
I've thought about doing that before as well :D
You can probably route it to the front somehow to gain maximum ramair effect...
dash
389
surrey
I doubt it will make any difference on the TDi appart from making the turbo whistle louder :blink:
Hardly any performance gained when ugraded to green panel + PD 160 intake:(
craig-pd130
353
Manchester
Visit site
Wasn't it driveforward who originally did the TSP (twin sh*t pipe) intake mod? ;)
Be careful that you don't suck in small animals and children ... you might get MAF problems :D
micky 32
630
Longford, Ireland
Visit site
With my car it will make a difference as i'm running 1.85bar boost. If i increase from that it starts to create a vacuum within the airbox and how i know is my MAF reading drops giving symptoms of a failing MAF so obviously the air can't keep up. To an ordinary chipped car it probably wont make any difference.
TBH i'll probably keep it at 1.85bar but i would say if i do this mod and increase the airflow my turbo wont have to work as hard to get the boost and i might be able to increase the fuelling without the expense of more smoke and maybe gain a few BHP.
basstard
Dropping Cogs is Useless
Aug 24, 2002
2,746
Roma, Italia
Visit site
can't believe it,,, more than 4 years and still the same pikey-risms,,, :lol: :p
ramair?! do you think you own a bike or what? Driveforward will be happy to know this is still around,,,
maxcars1
735
Heh Micky you know we were talking about this part that you can get from the stealers for your airbox, and SEAT dont list it; well, while i was changing over my waste pipes in my bathroom today i had an idea:whistle: I could use a 32mm right angle joint and attach it to my lover airbox, then like you said screw some hoover hose into that - would look quite OEM if i was to use all black products:D
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
I'm now leaving my stock airbox and green panel filter in. :) Was going to go down the BMC route, but Allard assures me the turbo gets plenty of air through the stock system - and I have the Cupra intake as well. I like the idea of adding another pipe into the system, but I imagine ultimately the bore of the pipe from airbox to turbo is what dictates the airflow - not the intake pipe (or 2 ;)) itself
basstard
Aug 24, 2002
2,746
Roma, Italia
Visit site
True indeed, but what I think micky is on here is the place where the airbox is fed cannot provide enough air anyway,,, maybe a front feed could do better,,, I guee it's a combination of the two: air feed and pipe bore,,,
