Running 1.6bar on the turbo you should see between 170-185 bhp dependiing on the mapping. Im running the KKBV39 and it works a treat. The boost will hold loads better with the FMIC - speak with Forge or Pro Alloy too if you want a FMIC, as they may do you one at a special rate if there isnt currently on the market
. Further, If you want some one to map after mods I have just the man - the file will be available from mine
Like i said before if you want that magic 200bhp you'll have to go hybrid. Interesting though ive heard that you could get the initial power as mentioned above without changing the injectors, so it may be worth do the other hardware, map the car and then if your not happy go buy the injectors.
