What does you car suck on? (The Induction Kit War)
padge16v
Humm, just took my car to stealth racing as the engine light came on last night, MAF sensor has gone wrong :cry: !, but they didnt recommend the K&N i was running, doesnt seem to have been running right on it when plugged into the VAG com and they havent had great experiences with them.
So going to try a BMC, they recommended it and everyone on here sounds pretty chuffed with theirs, just hope it doesnt make it much quietier!
slinger
142
north of watford
in my eyes the BMC is the best looking of all the induction kits, fits right in with the OE look.
for induction noise try either ram-air or dyna twist as these are louder than the BMC, the BMC hasn't got that much roar when you boot it, more of a slight low down revs rumble.
owners of both ram-air and dyna twist seem very happy with the performance and reliablilty of there induction kits.
if i was doing it over again, knowing what i now do i'd have gone ram-air, simply for the roar factor!
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
Ive got a split R on mine and i couldnt really hear it, now the noise comes back more though the K & N air filter. Got a Milltek cat-back exhaust too, but just doesnt seem to make much noise.
Milltek cat-back exhaust - is that the Resonated or NoN resonated version??
IBD
Here Again!
Jan 16, 2006
254
North West
Has anyone with an LC got the induction kit off could the give me the measurement of the internal dimension of the pipe that goes onto the MAF or the pipe to the old airbox.
When you have fitted the induction kits do some just get rid of the other small breather that goes into the airbox or what size mini filter will I need as I hav an induction kit to go on but the pipe is missing from the filter to the Maf, got it cheap so not complaining
Thanks in advance
Ian
Jan 3, 2006
834
East Kilbride
Thanks in advance
Ian
70mm on the LC and 80mm on the LCR's
I bought a seperate breather filter, can't remember the size but was under £10!
padge16v
Mine is the non resonated version, just doesnt seem to make alot of noise, although i have been uset to 2ltr novas and corsas in the past, different kind of car!
Harpic
I was just about to go to Awesome and get a K&N panel to go in 2001Cupra but am now thinking Green-but where do you get them from? Its wife car so she doesnt want whoooshing etc etc.
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
i've got a raid filter on my LCR, its exactly the same as the ramair filter. i got it direct from raid through their ebay shop
but the support bar that goes from the battery tray and attaches to the MAF has snapped some of the plastic on the MAF housing so now it moves about a fair bit. i'm thinking about putting the standard airbox back on with a decent panel filter until i can afford a BMC carbon kit. :( it was fine until i got it remapped!
Skorchio
Jan 23, 2007
1,570
Nr Milton Keynes
Can you hear it at all? Does it make a differance from standard? Seats have good sound damping so might be worth asking a mate when you drive past him what he thinks????
Im planning to get one quite soon!!
Harpic
sorry must be thick went to Badger5 but couldnt see asection on filters-I may need glasses sorry to a pain
smoothuk
SmoothNAV
Aug 26, 2005
589
Essex
KARLOS R
My ram air did exactly the same mate, snapped the clip off the side of the MAF, a small bit of fiddling and i knocked this up, i know it looks a bit tatty, but it works brilliantly, why they dont come with two brackets to start with i dont know...
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
KARLOS R
Please can I suggest that the solid bracket from battery tray to MAF is a poor idea. Body shocks are being transmitted directly to the MAF without any damping.
smoothuk
SmoothNAV
Aug 26, 2005
589
Essex
DJP, there is a large rubber washer on the battery tray end mate, and there is a rubber lining to the coller around the MAF, just cant see it ion the pic. Would that be enough do you think? Iv had it on for nearly a year now and no MAF issues to date!:whistle:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
The large rubber washer on the battery tray isn't the original is it?
If you're happy, I'm happy!
(I killed several MAFs when I originally had my RamAir on. Although it was probably due to over-cleaning, I'm a bit paranoid over MAF protection!)
I've refitted a RamAir recently. I have a Forge TIP which supports it well at one end. At the intake end I have a flexi-bracket across to the turret. I have a bubblewrap 'cushion' underneath the RamAir.
smoothuk
SmoothNAV
Aug 26, 2005
589
Essex
No mate, is it one i got off one of the John Deere tractors at work :), they wont notice it gone..:lol:
I only clean mine twice a year, need to order some more solvent cleaner actually. Does the TIP hold it well, i always wondered how well it would sit with one on as that is on the shopping list of bits to get. Think i have seen a pic of yours actually, is it that drilled ali rod????
