Currently running the Jabbasport set-up on my LCR. Not done any flow test though....wonder if it might be a good idea. How do i do them, is it a VAGCOM thing?
yes mate, measuring block 002 in engine.
Just fitted a K&N 57i filter, must say probably does nothing for the performance, but i love the noise from the dump valve coming back through the air filter and the chatter, lovely
just picked my bmc up 2day and it doesnt look like there much room in there for it. so u cut a few inch off the bmc or the bit it clips on2??
i [or rather my sister's husband] cut off about 1.5" - 2" off the actual air box, i had the idea after taking it off and looking how much "empty space" there was inside the box, as to not obviously cut the filter element cone thing inside, the end that was cut was the engine side end, if that makes sense.
here's what was done -
1. unscrew the end plate - engine side [oval shaped plastic end]
2. mark off on box how much wanted cutting all the way around.
3. cover filter element inside from any nasty dust etc - masking tape and newspaper did the trick, fiddly but ok.
4. use small hand held angle grinder [unsure what disc was used tbh, but i'll find out if needed] to cut the box.
5. remove paper and masking tape
6. re- fit end plate.
7. fit properly with cold air pipe to standard air feed behind LCR or try and find a better route - good luck if you do!
i'm well pleased with it now, felt really sluggish with the box before it was cut with no feed to it, but now it's sorted it just seems to rev harder, it's never going to be ram air loud, but it sounds cool [and fairly loud tbh] spooling up and a nice echo on gear change, even with standard DV and boost.
oh so u cut the box then. think i know what u meant got my slpiter R in the post to day so will be fitting the on sat and having a fidle aroud with it. did u usr the piping that came with it as it dont seem that bendy??
report back please on the sound of the BMC with the spit R DV as i'm after one if they sound good.
cheers mate, nice one.....it's prob not as loud after that as the boost will have dropped off a bit, re - map the car and it'll be even louder!
