Badger 5 DTH Throttlebodie Conversion
DTA EXP38 ECU
RPM 275 Cams
Piper Vernier Pulley & Inlet Cam Sprocket Vernier
RPM Gasflowed & Ported Head, Injector reccesses filled, mod'd combustion chambers, matched ported to TB's
ITG Megaflow 'Domed' Foam Filter
80mm trumpets
20vt Fuelrail, Injectors & 3 BAR FPR
Renualt Laguna Coilpack(?)
Ford Crank Trigger
AC pump, Rad & Pipes Removed
VW Mk3 Golf 2.0 8v Alternator & Bracket
Windage tray
Shrick Baffeld Sump
TSR 4-1 Manifold
2.5" Jetex 100 Cel Sports cat
2.5" Jetex Cordoba Cupra 20vt Exhuast
whats the size of the 16v?
