On a general German machine , Richard can upload a programme that will increase your spin speed by 1000 rpm , if its washer dryer , he can also add in an extra 30 degrees in temp increase .
We also have a soft fluff dry function for delicates and towels.It will also pair up socks prior to emptying.
The programme is switchable and not detectable by diagnostic software .
We can give you a before and after dyno sheet if you need one
please e mail spinlikea****[email protected]
The IPRO map,
is this the only one or have you more options or levels?
are those figures from using an inline filter on the water supply or just run of the mill h20 from any old uk tap
also would the dyno be at the flywheel or drum
have you been on the crack at forge today?
Rich can reprogramme your washing machine as well
Please let us know if you are interested and we will be happy to help you .
lol
I have some persil non biological wash booster, what sort of gains would i acheive?? Will i need to advance the spin cycle to rinse ratio??
Oh and i am using the liqui tabs... (if that helps.....)
