lcr lowering springs
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
thinkin of lowerein my lcr by about 20mm.wat are the best make??seen eibach ones but they are 30mm at back and 40 at front!!:shrug:
Just springs on OEM dampers?
Eibach should be fine but you need uprated dampers IMO otherwise you'll scrape everywhere, uprated dampers help reduce nose dive etc and therefore less scraping.
Splitters are cheap but under trays and sumps are not
kennyrodgers84
kennyrodgers lcr
thanks for the reply,yeah was thinkin bout usin the standard shocks but wasnt sure,just lookin a slight drop nothin extreme.
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
The suspension setup for the LCR is different to the normal Leon, by more than just ride height. So it should be the amount it lowers the LCR specifically.
AndyHazza
Ex-Awesome GTi Staff
Mar 30, 2005
1,455
Bolton
www.awesome-gti.co.uk
An Eibach prokit will normally drop a car by around 30mm, on the LCr i'd expect it to be around 20mm as they are slightly lower than the standard Cupra. What kind of mileage is your car on?
bigjode
504
spoke to eibach about htis directly when I was looking for springs for my LC - they said that LCR owners complained that the LCR springs were not lowering by more than 15-20mm, and that the LC sceanrio would probably be the same. This is because they had based their lowness on std leon springs - even if the LCR springs are unique.
Anyway, on my LC, they only lowered it about 20mm, even though it said 35mm :confused:
paullec
306
Birmingham
thought they did cause they list lcr fitment with some of the std range, so in thoery they should lower approx 15mm as LCR springs are 15mm lower ?
bigjode
504
An LCR is half golf/half TT mongrel isn't it? The golf range will obviously have allsorts in its range so 35mm on that would apply to the std ride height, non sport models, as for the TT I don't know.
You can check the part numbers on eibach's site and see what other cars huse that part number
Ruddmeister
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Yes
TT/S3 front end and Golf Mk1V rear
kennyrodgers84........
I did a small thread on LCR suspension here, although it concentrates on coilovers etc
http://www.seatcupra.net/forums/showthread.php?t=91243
May be of some use :shrug:
