Idle Issues
Drew1982ish
Hi to all - this is my last resort - i have searched this site previously to no success - i have leon cupra 2001 - with speradic issues when idling - it has been into the dealership whilst under warranty and they have replaced everything from turbo to vacuum pipes, 75 valve, temp sensor, DV valve (twice) lombard sensor (thrice) replaced air box now for carboni but still the problem persists and garaunteed if i take it in again it will run fine, may show a fault with one sensor but they are all bran spankers, I need your help guys it is starting to cost me a fortune everytime i take it in i get charged for diagnostics they see a fault reset it test drive it, doesnt re appear so they give it me back charge me hours labour and send me on my way, Please please please give me a clue, and yes i am begging. :help:
Drew1982ish
whilst idling the revs, they drop and pick up like it is struggling to breathe - or miss firing but like i said in orginal post everything is bran new - even spark plugs and leads are new (standard, but new)
Drew1982ish
even the MAF is new - and new one been cleaned im gettin to point of giving up but cheers for help
Jay20VT
The 'R' In CupRa
Jul 23, 2004
658
82
N.London
Hi mate, this problem sounds very much like one I used to have with my Mk2 Golf GTI. It was on a 'G' plate and this was quite a common problem. When I took it in I was told the 'idle control stabiliser' was knackered, so I got that changed, but it didnt sort the problem completely.
In the end after speaking to several people I was told that the idle adjustment screw maybe clogged with soot or carbon build up, so one morning I took it out of its housing near the injection system, cleaned the screw and its housing with WD40 put it back in and wallah!!! :funk: :funk:
Now, I'm not sure if this set up is similar on your car but perhaps worth looking into. Good Luck!!
Drew1982ish
im not a genius at these things but where abouts is iidle screw? is it in throttle body? and would it by any chance show up on diagnostics or just throw every other sensor out of line? usually thorws up lombard, dv valve or boost control - I really appreciate ure help mate thanks
Jay20VT
The 'R' In CupRa
Jul 23, 2004
658
82
N.London
now worries, in all honestly I am only telling you my previous experience and what I did. I would have thought it was in the throttle body but I am not very familiar with these engines, perhaps worth asking a mechanic?
As I said this problem was with a G reg GTI, technology and engine architecture changes all the time.
Drew1982ish
That is true - i know where throttle body is but i dont dare to take it off - baring in mind it has been into a seat dealer on 15 seperate occasions for same problem i would of expected them to come to a conclusion - but thanks very much for your help i made a note and will get them at weekend - CHEERS!!
Jay20VT
The 'R' In CupRa
Jul 23, 2004
658
82
N.London
hope u get it sorted fella, do let me know if you get a result.
Drew1982ish
will do - cant think of anythign else - altho i have mentioned throttle body before but being under warranty seat just fobbed me off as would be too expecive to replace etc
Jay20VT
The 'R' In CupRa
Jul 23, 2004
658
82
N.London
i tell ya what i would do? simply cos i can be an annoying git is complain about this issue to SEAT UK, fancy going down that route?, even though out of warranty now still an unreasonable ammount of revisits to get a problem sorted whilst under warranty. Breathe down their necks HARD, you may just get a result. Try...
Pabs
5,936
Basingstoke
had this and reported it to my dealer twice.
2 new MAF's later and problem solved - virtually. Still does it occasionally but nowhere near as bad as it was.
Jun 28, 2001
1,533
how low does the idle drop??? does it stall and are you resting your foot on the clutch pedal at same time???
Drew1982ish
on occasions it is really bad and drops to the point of cutting out - but doesnt actually cut out - i must admit as well it does do it mor violently when foot on clutch - but again foot off it can do it just as bad - clutch piston has also been replaced re sticking clutch pedal - GOBLE wat do you suggest??
Drew1982ish
i have they dont seem to want to know - i nearly took seat dealership to court they were that crap - but doing that would still not of got my problem fixed - plus it is now out of warranty - so they tend not want to know unless i am paying them - and just to take a wheel nut off they tried charging me £70 for one hours labour - but will investigate further -
Ste
47
Does this happen when coming to a stop as well as idling? I had a problem on my old Polo where the revs would drop and even stall when slowing down. Turned out to be a problem with the ECU software - apparently very easy to fix. Ran like a dream after this was diagnosed. Maybe something to consider when you take it back.
Also, might be worth taking your car to another garage, that has diagnostic tools. Sometimes, a new mechanic/garage can detect a problem very quickly.
