First car breakdown in 9 years, Advice :(
paullec
306
Birmingham
Well after 6 cars and 9years tonight i had my first breakdown in the LCR :cry: Gave it some welly up this hill and the engine temp needle swung round to 120 and did its rude beep noise on me. Anyway iv had a dodgy needle reading for a while where it reads anywhere between 0-90 and on occasional days its lazy and decides it doesnt even want to play.
My question is if the needle was really on 120 and red light on. i have no loss of power or such and the climate control diagonosis (51c) reads a nice constant 90deg can i put it down to the dodgy sensor or what symptons would/should i have if the needle was really reading 120deg?
GrayT
I'm Old
Jul 7, 2004
812
London
Engine will be hot! Are the fans cutting in? Be worth checking your fan fuse as it is a known fault that they burn out (one of the set of 3 on top of the battery).
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
It's almost certainly the water pump, do not drive the car if possible or drive it slow (below 50mph) the impellar on the pump is breaking up to be specific
If you drive it the pump could totally fail which will mean a new engine
Get it to a garage pronto
Oh and new pump = new cam belt and tensioner too
It's not unusual for the temp to stay normal below 50mph but when the turbo starts working it rockets to 120deg and the light comes on
paullec
306
Birmingham
I would of said the engine was as hot as normal :S not over hot. Was no hiss when i took the coolant top off to have a gander.
paullec
306
Birmingham
What does (51c) on the climate control diagnosis temp read then ? as this was a constant 90deg. Oh well now i have to phone up a garage on see what happens
andycupra
status subject to change
water pump is a weak point.
however, you have said the gauge had played up before and that you are getting a different reading from the climate control...
which does point the finger at the gauge being possibly at fault.
but on the other hand you dont want to cook the engine.
id get it to a garage and drive it very gently.
paullec
306
Birmingham
yeah will take it in. Strange but after doing loads of searches the temp does go up with the revs thinking about it, even tho the climate control temp reads 13 at start and 90 constant while i was limping home : ( Had a temp sensor on order for the 27th looks like its going to haunt me.
bigjode
504
the 51c temp display is read from somewhere other than the coolant system. I know this for a fact because when I had only half a thermostat in the car and the coolant system was underheating and dropping temp between 90 and 60c, the 51c stayed at 90. My guage wasn't faulty, it was accurately reading the coolant temp and even when the guage said 60, the 51c display stayed at 90.
Also tried this once - took the coolant temp sensor out of its hole and dropped it in a cup of water while still connected to the loom - the guage dsplay shot up to 100c or so (because the water was boiling hot) but the car was stone cold. the 51c reading didn't match at all.
Ruddmeister
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
I doubt there is a sensor issue here, I think once the water pump is replaced all will be fine.
I wouldn;t rely on the climate display readout for anything other than the speed (KM/h) which seems fairly accurate
Sam20v
949
Dubai UAE
Visit site
I had a dodgey needle too, sometimes reading 0 sometimes off scale hot, but no overheating detected under the bonnet. wasnt my temp sensor, it was the Sender gauge, apparently its different..........:redface:
Bogwoppit
1,085
Lincs
Depending on your mileage, whilst replacing the water pump it might be worth replacing the cambelt as well.
The cambelt has to come off anyway to change the water pump.
paullec
306
Birmingham
Well it went in today there doing the full pump, cam, tensioner and sender and brakes all at once lol and only at 31k :( oh well at least io dont have to worry about a cam belt change at 50k lol lets just hope they find nothing else apprently it a very very very common fault you would of thought audi volks seat or whoever would of done something about it.
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
Have you upgraded to the metal impeller rather than sticking with the plastic?
From what i have heard its a must ;)
