Gonna start this with a How To... if I may
Couldn't find any info on removing the airbag on a Toledo (or Leon, Golf, Octavia) ...
... course, it's pretty obvious once you have a spare wheel infront of you, but I have an inane fear of failure when it comes to working on the car and wanted to read up on it first
Anyway, easy doesn't even describe it -
(s'pose I should put some sort of safety warning on here - disconnect your battery and wait 30mins before attempting to remove or tamper with an airbag or it's connectors)
Turn the wheel to about 10 o'clock and locate one of the holes in the back of the wheel
Insert a screwdriver and lift the handle up - outwards from the wheel
it's these clips you're trying to push inwards
If the airbag doesn't pop towards you, give it a gentle pull and rotate the wheel to access the hole on the other side.
I think the bolt in the centre of the wheel needed a 12mm splined socket and you just need to be sure that the new wheel is located on the hub in the same position as the original was when you removed it.
Airbag just pops back on when you're finished.
Result -
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
And that's Phase1 complete. No prizes for guessing what Phase2 involves![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![2255235_28_full.jpg](http://memimage.cardomain.net/member_images/11/web/2255000-2255999/2255235_28_full.jpg)
![2255235_29_full.jpg](http://memimage.cardomain.net/member_images/11/web/2255000-2255999/2255235_29_full.jpg)
Result -
![2255235_26_full.jpg](http://memimage.cardomain.net/member_images/11/web/2255000-2255999/2255235_26_full.jpg)
![2255235_27_full.jpg](http://memimage.cardomain.net/member_images/11/web/2255000-2255999/2255235_27_full.jpg)
