Yeah sorry feel the 212 was logs on my car and was a spike, it was mainky around 210 (will post logs when i find them again, bloody work laptop). My point was that 210 seems way too high to me for stg 1, would expect 190ish
Like I said earlier and in other threads - I've seen 205-210 g/sec with Stage 1, but only in January/February.
Neilc posted earlier that Revo quote 190-205 for Stage 1 - that definitely sounds right for what I've seen logging my car and others over the past couple of years or so.
I take it you're assume that Stage 2 will out-flow stage 1 by some huge big margin? There's only 10-15 bhp difference in peak figures, that's only 13-20 g/sec. If a stage 1 and stage 2 car will flow roughly the same at roughly the same time of year, you'll see why a few people will says stage II is not worth the money :bleh:
In fact, both mine and ice maiden's car is out-flowing yours at the minute :bleh:
Anyway, enough of my willy waving (as large as it is) - what we should do is graph all these MAF, Requested vs Actual boost logs together to form a factual database of, erm, facts.
Edit:
http://www.seatcupra.net/forums/showthread.php?t=90345
http://www.seatcupra.net/forums/showthread.php?t=98337
email me logs of 003, 115 and 020 (what else?), mods, stage 1, 2 or 3 (and choice of turbo for 3) to "cafe dot racer at ntlworld dot com" and I'll see what I can do.
I've had no emails :D
But anyway, I just wanted to post that I saw 205-209 this morning (even though it's bouncing around like a bitch - dodgy N75 I think...)
would a split in that hose meaning the maf is reading lower air flow in turn cause less fuel to be put in and me to run higher cf's as i am boost 9 timing 6 at the mo and in the 4th cf colun i see some 5's and 6's but only at about 1800rpm
Anyway i finally got off my backside and did a log. It was a bit 'finger in the air' as i couldn't remember what i had on before so stuck it on T7B7. I think i can get more out of it but it seems quite revvy at this so it might stay. Stg 2 lcr. Ignore the first few CF's, it's just cos i started the run at about 1k revs.
Code:
Group A:	'002				Group B:	'115				Group C:	'020
	RPM	Load	Inj. On Time	Mass Flow		RPM	Load	Absolute Pres.	Absolute Pres.		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME					TIME					TIME
STAMP	 /min	 %	 ms	 g/s	STAMP	 /min	 %	 mbar	 mbar	STAMP	 CF	 CF	 CF	 CF
461.4	1960	96.2	8.16	41.92	460.8	1880	62.4	1190	1020	461.1	0	0	0	5.3
462.3	2200	124.8	10.54	60.36	461.69	2040	104.5	1740	1270	461.99	0	0	0	4.5
463.21	2520	172.2	14.62	96.22	462.61	2280	136.1	1930	1660	462.9	0	0	0	4.5
464.11	2880	182.7	15.3	101.86	463.5	2640	181.2	2190	2260	463.81	0	0	0	3
465.02	3320	191.7	15.98	123.19	464.42	3000	188.7	2230	2190	464.72	0	0	0	1.5
465.93	3680	191.7	17.34	152.69	465.32	3440	191.7	2300	2240	465.63	0	0	0	0
466.83	4080	191.7	18.36	164	466.22	3840	191.7	2360	2350	466.53	0	0	0	0
467.74	4480	191.7	18.02	178.31	467.13	4240	191.7	2380	2370	467.44	0	0	0	0
468.64	4840	191.7	18.02	189.81	468.04	4640	191.7	2350	2350	468.34	0	0	0	0
469.55	5160	191.7	17.68	200.25	468.94	4920	191.7	2320	2300	469.25	0	0	0	0
470.45	5440	191.7	17.68	211.78	469.85	5280	191.7	2290	2290	470.14	0	0	0	0
471.36	5760	191.7	17.34	209.92	470.76	5560	191.7	2260	2220	471.06	0	0	0	0
472.26	5960	191.7	17	218.08	471.66	5840	191.7	2230	2190	471.96	0	0	0	0
473.17	6200	181.2	15.64	213.64	472.57	6040	186.5	2200	2200	472.87	0	0	0	0
474.08	6400	178.2	15.3	217.72	473.47	6280	182.7	2180	2140	473.78	0	0	0	0
474.98	6600	167.7	14.62	217.22	474.38	6440	172.2	2180	2220	474.68	0	0	0	0
475.9	6760	168.4	15.64	218.94	475.28	6640	170.7	2170	2180	475.59	0	0	0	0
476.8	6880	156.4	14.96	218.53	476.2	6800	172.2	2180	2170	476.5	0	0	0	0
477.71	7000	158.6	14.96	219.39	477.09	6960	160.9	2180	2170	477.39	0	0	0	0
478.6	7160	167.7	16.32	225.08	478	7080	163.9	2190	2170	478.3	0	0	0	0
What I meant by posting this is that in the space of about two weeks, as the ambient temp dropped (to 3.5'C) mine's gone from mid 190's to 209.
See post 41 :shrug:
Code:
TIME					TIME					TIME
"Nice" :D
I took some reading the other day and got this below... im not sure if my maf is working properly, can anybody advise? its a 2003 leon cupra standard...
Code:
Time	Idle speed	Engine load	Inj. period	Air mass in	Time	Engine Speed	Engine Load	Spec. Boost	Actual Boost
35.76	720		17.3		2.04		2.56		36.16		720		17.3		970	970
36.56	720		18		2.38		2.78		37.06		720		18.8		970	970
37.47	1000		30.1		3.4		5.75		37.87		1240		34.6		970	970
38.27	1320		45.1		5.44		12.56		38.78		1120		55.6		970	990
39.18	1200		60.2		6.12		16.06		39.68		1520		51.9		970	1040
40.08	1800		48.1		5.44		17.33		40.48		2080		53.4		970	1050
40.9	2400		54.9		5.78		26.5		41.3		2320		15		970	1050
41.7	1920		13.5		0		3.92		42.1		1760		45.1		970	970
42.5	1840		65.4		7.48		24.75		42.9		2080		73.7		1080	1100
43.3	2360		80.5		8.5		37.97		43.71		2560		72.2		1000	1260
44.11	2760		66.9		7.14		35.22		44.51		3040		94		1380	1250
44.91	3320		100		10.54		58.44		45.31		3520		60.2		1080	1260
45.71	3800		120.3		13.6		100.42		46.13		4160		130.8		1590	1620
46.64	4640		130.1		13.26		116.75		47.12		5080		128.6		1530	1520
47.53	5400		126.3		14.28		130.25		47.93		5480		16.5		970	1390
anybody pls? Im phoning to see bout apr tuning today but i don't want to book anything if my maf is buggered?!?!? will it matter bout the apr remap if my maf is buggered, so when i get a new one it will work better with out affecting the remap?
PS how the hell do you get the maf out??? it looks like a torx security bit, but my torx security bit the hole is too small, is there a special tool or is it pot luck on torx manufaturers as tro gettting a bit that fits?
Any anybody got a part number for maf?
for a standard LC your mass flow readings look about right!
When remapped you should see around 160 - 180 g/s on a k03s turbo which yours should be
hope that helps, get it remapped anyway, just take logs again after to see if you are getting in the above range.
Im starting to like this cold weather :D
Logs are from a totally standard Leon FR, air temprature was around +2degC
Code:
3000	           18.8	          1.7	          16.28
3960	           97	          11.9	          91.14
4320	           121.1	  12.58	          98.86
4560	           121.8	  12.92	          105.61
4760	           121.8	  13.26	          112.03
5000	           139.8	  16.66	          137.86
5320	           139.8	  17.34	          142.47
5600	           137.6	  17.68	          145.56
5880	           133.8	  17.34	          150.19
6040	           127.8	  15.3	          112.11
4720	           107.5	  14.62	          120.58
4840	           138.3	  18.02	          129.69
5000	           136.8	  17	          130.03
5120	           136.8	  17	          132.97
5240	           137.6	  17.34	          135.61
5360	           139.1	  17.68	          143.19
5480	           138.3	  17.68	          145.11
5560	           139.1	  18.36	          147.25
5720	           137.6	  18.36	          150.67
5800	           134.6	  18.02	          149.19
Code:
5760	           135.3	  17.68	          148.47
5880	           133.1	  17.68	          149.94
6000	           130.1	  16.66	          148.69
6120	           130.8	  17.68  	  150.67
6240	           127.8	  17.34	          153.64
6320	           126.3	  17	          152.89
6440	           124.8	  16.66	          153.39
