over reving
Jun 7, 2006
2,983
Norfolk, Norwich
a little off topic i spose...
what happens if u over a rev a car???
and would u say u might of caused damage if u come off a round about in 2nd shift for 3rd on full steam miss the gear and then rev round to 5500rpm :whistle:
seems to be driving ok.. and i worry to much but thought id make sure
Smee
Jul 17, 2004
1,829
West Lothian
I mis-shifted into 6th the other week when overtaking on a dual carriageway and after a minor panic, there didn't appear to be any problems and I stopped worrying. :redface:
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
If you beat the rev limiter say changing down and over revving on the petrol 1.8T it logs the over revving in the ECU with a code saying **warranty invalid engine over rev** or something similar
Diesels may be different
EdButler
713
Sheffield
You should be fine mate, the rev limiter and red line on a diesel is more because they are completely useless power wise at those speeds to theres basically no point taking them there... Dissimilar to a petrol, where its there as a safeguard for the moving parts exceeding their rated speed.
Diesels will still be as balanced and durable to revs as a slow-ish petrol engine so you should be fine. There will probably be a fault code though, which you an remove within about 10secs!
Just chill out with the gear changes; faster changes barely speed you up day-to-day. Also the selectors, as a few people on here have proved, are not the cars strongest feature.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Damn you Ed, beaten me to a techy reply again :D
I didn't think the "max engine speed exceeded" fault could be cleared with vag-com though :shrug:
EdButler
713
Sheffield
Hehe sorry Muddy, we both seem to reply to threads in bursts, strangely during work time :rolleyes:
Yeah you can clear it... I did it twice, once a 1.2 Petrol and a 1.9TDi 130, both after theyd just been into the stealers... :blink: Just log into the engine block and its there in big caps, it deletes just like any other codes.
Triple D
IIRC J@MES had that over rev engine speed code come up after he did 160 in his LCR, it also came up with warranty invalid :) on it aswell, think he deleated it.
