Hi, has any one used or heard if this is any good, especially for keeping the inlet valves clean.
Here’s some info I found in the AudiWorld forum.
DIRECT INJECTION POWER 3
Air Intake Cleaner – Spray can
DESCRIPTION
Wynn's Direct Injection Power 3 is an aerosol product developed for cleaning the air intake system of direct injection petrol engines.
PROPERTIES
Provides immediate thorough cleaning of air intake system and inlet valves.
Strong power jet spray to support cleaning action.
Dissolves gum, lacquer and deposits.
Easy to use, cleaning takes only 5 minutes, no dismantling of components necessary.
Restores or maintains the engine performance.
Eliminates and avoids starting problems.
Improves acceleration properties.
APPLICATIONS
Recommended to be used at each service interval to maintain cleanliness of the air intake manifold, inlet valves and EGR valve of direct injection petrol engines.
DIRECTIONS
Warm up engine. Remove the air filter.
Run engine up to 2000 rpm.
Spray 200 ml product in short burst into the air intake manifold.
Rpm will drop during spraying. Allow the revs to pick back up before resuming.
If necessary, increase the throttle to avoid stalling.
Let the engine idle for a few minutes with occasional increases in throttle, but do not exceed 3000 rpm.
Leave the engine running for at least one minute after the last acceleration.
Stop the engine. Put filter back in place.
TECHNICAL DATA
Appearance : clear liquid
Density at C : ca. 0,736 kg/dm³15
Flash Point : < C21
Propellant gas : propane
DESCRIPTION
PROPERTIES
APPLICATIONS
DIRECTIONS
TECHNICAL DATA
Flash Point : < C21
