wishbone help needed could be the wheel bearing
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
what holds this up? basically i just tried jacking one of my front wheels up and it didnt rise? the chassis just went up and the wishbone went down. i got the wheel off and it had dropped further and i had to jack the wishbone up so the hub was high enough to fit the wheel? everything seems connected?
also got a grinding sound developing which is why i checked the wheel in the first place thinking a stone had got caught in the brakes
trying to sell the car and this is not what i wanted! to top that i'm stuck in work
jivejester
336
also with this a new grinding sound has developed which is why i checked the wheel in the first place thinking a stone had got caught in the brakes
Check the strut top mounts are all ok, and the strut itself.
Are you sure your not just dreaming lol
jattjoka01
109
London
i took my car to an independant garage... as i thought my tracking was out... and needed sorting...he took it for a drive...and came back... and then fullly loocked my wheels and explained and shwoe dmy that the wishbones where getting weak...(he showed the movement of the bone with a screwdrvier) :(
acidstrato
Dec 9, 2004
5,942
lol its possible, forget the wishbone for now, as i think the noise is the wheel bearing going as its louder when i turn left. it makes a strange rubbing sound as i drive slowly and crackling/grinding.....ring any bells?
i did have a look at the strut top mounts they are seated fine, will have another look
jivejester
336
cv/bearing
