A few 2010 european-based Winter Tyre test results:
http://www.tyrereviews.co.uk/Article/2010-European-Winter-Tyre-Test.htm (225/45/17 tested)
http://www.tyrereviews.co.uk/Article/2010-European-Winter-Tyre-Test_2.htm (185/65/15 tested)
http://www.tyrereviews.co.uk/Article/2010-Auto-Zeitung-Winter-Tyre-Test.htm (195/65/15 tested)
http://www.tyrereviews.co.uk/Article/2010-Auto-Bild-Performance-Winter-Tyre-Test.htm (245/45/18 tested)
Bear in mind that some European tests will focus more on snow performance depending on location & typical weather; in UK I'd say you want a good balance of dry/wet/ice/snow performance all round.
EDIT: If you cover a reasonable mileage every day, it's worth noting that a lot of tyre tests now test rolling resistance too, which could have an impact on fuel consumption.
Need a new pair of tyres for the Passat, as two of the Wintersport 3Ds are quite low now...the Continentals TS830s are looking like a good candidate....similar results to the 3Ds but with lower rolling resistance. Hmm.
