Will a remap lower my 0-60
OFI
350
Salisbury
Who would you recommend? Revo is interesting as it's stealthy, so I hear.
Does anyone custom map and take you out on the road while hooked up to a computer?
Pal of mine had his CRX with Nitrous mapped like that, added launch control while they were kicking it round!
Have a look at the sponsors on here.
What do you mean by stealthy?
Any mapper that doesn't have a rolling road will probably do it like that :p
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
But what it doesn't lose goes straight to the tarmac :D Although still a perfect launch should be closer..
Is the S3 lighter? I'd expect it to be heavier...
Thought S3 would be heavier especially with the AWD system to carry too, but interesting, I'll look it up.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Stealthy as in I thought the dealer/ mechanic or insurer will not find it in there without searching it out.
Also can't the Revo be reversed in an instant?
Dani_b19
301
On average without a driver there about 1400kg but that can give or take 50kg depending on extras etc.
Yeah you have got a point, havent managed to spin the wheels yet, wet or dry.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Audi S3 3 door 1935 kg gross weight aparently
These are from the technical data from Auto trader
could be wrong.
Thats an03 S3, is the new one all alluminium? would be lighter
cap r 225
the need for speed!
Feb 24, 2008
974
nantwich
www.seatcupra.net
Evo magazine state's the LCR weighs 1376kg? That's not even close to what you guys have said???? Surely nearly 2 tone is a bit heavy for a average size car, aren't rangerovers 2 tone?
Dani_b19
301
Mines the old s3.
Thats b***ocks, the s3 does not weigh 2 tonnes, mine weighs 1461kg so id love to know what extras id need to get upto the 1900kg.
S3 Nattie
120
lol i was thinking same as you dan, 1900kg is closer to a Bentley or Range Rover than a S3.
Quite surprised at what you guys are getting 0 - 60. Do you need 3rd gear to get to 60. On a S3 you can but you would have lost boost a long time ago.
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
Mines the old s3.
yeah the standard lcr is 1350kgs, and the s3 is a bit heavier. interesting to see the 60-100mph time difference.
well i get to 60 just before the end of 2nd gear. the biggest factors in the times in my experience would be launch and first gear change.
btw, is it best to rev it to as far as it goes on a remapped lcr? because i can rev to 7.5k as apposed to 6.5k standard but iv heard that the power tails off so its better to change earlier?not sure on that one!
OFI
350
Salisbury
From what I understand many cars don't have peak power right at the top end but you rev that bit further to compensate for the drop in revs during the change.
That might be rubbish the racers on here should know. where's Bill? :p
OFI
350
Salisbury
They're all invisible to the eye if that is what you mean. If the ECU was read and compared to a standard map then it could be seen I suppose.
Revo can supply a switch to 'turn off' the improved map but it doesn't turn it off as such it just switches to a Revo version of the standard map. When you are remapped the standard mapping is gone.
Obviously you should inform your insurer if you get a remap and wouldn't post on a public forum that you had done anything otherwise ;)
Dani_b19
301
Well i can reach 60 in second on mine and still just be on boost but i know other guys who have to change to third to hit 60, the only problem ive got is that second crunch's on mine so sometimes it can be a bitch to get into it if changing fast.
JamJay
California Bound
LCR 225 & S3 225 Comparison
LCR 225
Year Introduced: 2003
Kerb Weight: 1376kg
Engine Type: Straight 4
Valves: 20 valve
Cylinders: 4 cylinder
Aspiration: Turbocharged
Displacement: 1781 cc
Fuel: Petrol
Drive: FWD
Transmission: 6 speed Manual
Engine Location: Front Mounted
BHP: 222 @ 5900rpm
Torque (lbs/ft): 206 @ 2200rpm
BHP/Ton: 164
0-60mph: 6.9s
0-100mph: 16.0s
60 - 100mph: 9.1s
1/4 Mile: 14.93s
Top Speed (mph): 150
S3 225
Year Introduced: 2002
Kerb Weight: 1420kg
Valves: 20 valve
Fuel: Petrol
Drive: 4WD
Transmission: 5 speed Manual
BHP: 225
Torque (lbs/ft): 207
BHP/Ton: 161
0-60mph: 6.4s
0-100mph: 16.4s
60-100mph: 10s
1/4 Mile: 15s
Top Speed (mph): 151
Faisal
May 27, 2008
1,445
Most likely at work
from that info it looks like the LCR is better than the S3 in every way apart from the 0-60 time :confused: which is great i suppose lol
Off topic, but great suggestion, I've known of lap timers for iPhone for ages but I can run RaceChrono on my Nokia and it's free! Will give it a go tonight, what do you think of its accuracy?
racechrono is alright,im still trying to figure out how to use it properly for 0-60 times. you have to have it in clear view of the sky, and the annoying thing is, you dont know when it starts. as soon as you get a satalite lock, go for it as it ends up starting when it wants to if not.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
It did look like those figures I found were heavy, espcially the S3
Can't rely on much info found on the net any more sorry guys.
