Wheels Spacers...
Adam R
Diesel ISN'T a Dirty word
Mar 5, 2007
2,851
lee in the solent
what you running now then! i believe i have your 20mm's!
The 20mm on cupra wheels sits pretty! and it handles sooo much better now!
AMC.
yes your right, on the back with cupra wheels and 20mm spacers the wheels sit perfectly in the arch.
one big problem i have found though is i suffer from understeer now, as when before it used to be more oversteer.
that is my only complaint about rear spacers.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
.......more over I bet its not more understeer for the same speeds tho, just higher speeds before the front pushes vs the backs being planted.
amazing the different 40mm track width makes
Adam R
Mar 5, 2007
2,851
lee in the solent
i find roundabouts can be quite interesting as its impossible to 'lift off' oversteer to get the back end out slightly.... now the car grips very well but if anything if going to brake loose, its always the front wheels now. nice to know that though when you go around tight high speed corners ;)
