.......more over I bet its not more understeer for the same speeds tho, just higher speeds before the front pushes vs the backs being planted.
amazing the different 40mm track width makes
i find roundabouts can be quite interesting as its impossible to 'lift off' oversteer to get the back end out slightly.... now the car grips very well but if anything if going to brake loose, its always the front wheels now. nice to know that though when you go around tight high speed corners
