What wheel spacers with OEM 19" wheels
stugee106
21
27
Hi,
I was wondering what spacers people are running with the the OEM cupra 19" wheels? Also can you post any pics with them fitted?
Dannnnn
No longer active
Dec 9, 2018
440
200
Hampshire
12mm front
15mm rear
These are the vagsport ones from progressive parts.
Sent from my Pixel 5 using Tapatalk
Reactions: stugee106
Fishbowlhead
Mk3 CupraST 280
Nov 20, 2020
148
80
UK
I went 15 front & 15 back. Did have 20’s on the back but they were causing massive arch rub so had to step down to 15’s.
Reactions: Cuprabenwytm
Cuprabenwytm
323
110
I hope the 20s dont cause too much rub, are you estate or hatch
Sent from my MRD-LX1 using Tapatalk
Cooper2020
17
12mm front
15mm rear
Hi, sorry to revive an old thread. I fitted 12mm front 15mm rear on my 290 and the front tyres were rubbing on the wheel arch plastic winglets/spoiler thing. I'm going to remove these. Does anyone know what there actual purpose serves.... cheers.
SRGTD
2,680
1,528
Car manufacturers fit those little plastic lips / wheel spoilers when there”s a risk the tyres may extend beyond the wheel arch edge. They are intended to cover any exposed sections of tyre tread when viewed from directly above the wheel - I believe that legally (in the UK), and for safety reasons, no part of the tyre should extend beyond the bodywork when viewed from above.
Fishbowlhead
Mk3 CupraST 280
Nov 20, 2020
148
80
UK
I posed this to my mechanic when he did my spacer’s, basically to let you know the wheels are rubbing before they rub on the actual arches.
Edit. Seems i was way off.
