Deano j1971
586
632
Can you remove the grille without removing the bumper?
I want to wrap my bottom lip gloss black
@K290b... I had the lower part of the bumper wrapped last week gloss blk mate,no need to remove anything and it looks sh*t hot.
Sent from my COR-L29 using Tapatalk
k290b
116
88
That does looks good
Is that a Rieger splitter too? I’m getting one of them but can’t decide on gloss or matte
I’ve been quoted £45 to wrap the lip
I tried it myself last night and made an arse of it
Deano j1971
586
632
@k290b....I know what you mean when you say that, I managed to wrap the front S badge and the red part on the Cupra flag but I kid you not it was not easy. Yeah it’s the Rieger front splitter, I have the rear diffuser as well in the gloss blk it’s a kind of colour theme I’m going for if you know what I mean.
Reactions: Maypack
May 3, 2019
11
The sensor itself seemed ok in my case, but the plastic supports, from cover and mount piece were shattered. So they required replacing. I used Carista to reset the fault codes and it has worked well (ish) since then. I do appear to have another problem related to my front lights that will disable the front assist after around a few minutes of driving though... haven’t bothered to get round to fixing that yet.
Depending on how much space there is in the grille to fiddle, it might be worth checking to see whether the connector at the bottom is dislodged too.
Thanks Yes it generally seems intact and connected. I will have a crack at
It later in the week when the unit arrives.
I definitely don’t want to be paying out for a recalibration!
ray
590
191
Washed it and use a new ceramic coating, again cheap crap but I’m happy trying new things, this one gives good initial results...
Used pro kleen snow foam, maguiars tyre gel and the cheap coating quoted above. Decent results.
Sword
105
43
Winchester
No need to remove the grille, with a plastic card the film can be tucked into the grille.
Little tip, if you are doing it yourself use some felt and tape it to the end of the card, stops scratching or cutting the film.
Walone
1,679
489
Near Heathrow
Changed my wheels front to rear/rear to front to even out tyre wear as I like to change all four tyres when the time comes to renew them.
Fronts were about 4mm and rears about 5mm at 14500 miles. Had to use a sledge hammer on the inside of rims as the wheels were seized on. Used a wire brush to clean the corrosion off the hubs and inside the wheels then applied some anti-seize titanium grease, hopefully they won't seize again. Also checked the brake pads front and rear, less than half worn. I noticed that my car doesn't have pad wear sensors (16 MY, FR ST 1.4 Act). Also checked the shocks to make sure there was no sign of leaks or 'misting', all perfectly dry.
k290b
116
88
Washed the cars added another coat of auto finesse tough coat
Ordered a gloss black Rieger splitter today
Might get the rear diffuser too...
Deano j1971
586
632
K290b...nice one you won't regret it. I know they don't come cheap but they look the mutts nutts. The rear diffuser looks great too. Don't forget to post some pics when you've installed it please.
bgb
600
316
Not what I’ve done, but brought a rear badge (flag etc) and wondered if anyone had any measurements or could take a square on pic of the rear of their Cupra Leon Hatch?
Much appreciated in advance!:thumbup:
bgb
600
316
My last post help you at all mate?
yea does give me an idea, wanted a lower down view if you get what i mean so when I'm lining up the edges I've got reference points, edge of reverse light etc.
