Weird engine noise ?
CupraR_Lad
515
Herefordshire
Hey guy's
My car make's like a grunting noise when i pull away,sort of like a grrrrrrr!!I think it's when there's strain on the engine!
It's hard to explain!Coming somewhere from the engine bay Any ideas?
gib20vt
166
Cumbria
does it sound like a bit of plastic vibrating? as mine just started this before coming home from work, sounds lie its coming for the aux belt area
gib20vt
166
Cumbria
hhmmmmm, I will have a closer inspection of mine tomorro and see - but as you said mine happens when I just ease off the clutch
B3LSY
could be the bearings going on the clutch,does the sound go when the clutch is down?
CupraR_Lad
515
Herefordshire
Yep. Handbrake on, engine running, in gear, bring car to biting point and quite a burble. Doesn't sound nasty on mine. Does it on yours?
Yep that's the same thing as I'm hearing,no it doesn't sound nasty,it's quite beefy! :)
Just wanted to know if I should be worrying about it!
