CupraR_Lad
515
Herefordshire
Hey guy's
My car make's like a grunting noise when i pull away,sort of like a grrrrrrr!!I think it's when there's strain on the engine!
It's hard to explain!Coming somewhere from the engine bay Any ideas?
does it sound like a bit of plastic vibrating? as mine just started this before coming home from work, sounds lie its coming for the aux belt area
hhmmmmm, I will have a closer inspection of mine tomorro and see - but as you said mine happens when I just ease off the clutch
could be the bearings going on the clutch,does the sound go when the clutch is down?
Yep. Handbrake on, engine running, in gear, bring car to biting point and quite a burble. Doesn't sound nasty on mine. Does it on yours?
Yep that's the same thing as I'm hearing,no it doesn't sound nasty,it's quite beefy! :)
Just wanted to know if I should be worrying about it!
