mark90
83
rear washer...found wipe split in engine area..fixed...still didnt work...
found that some how the rear nib/washer jet is broken..the top is gone...as in the nib/moveable metal squirt hole!!!
what part do i need??wheres best place to get it?
might help
my jet went the other nite, the cold weather causes it to like freeze i believe and wen u try tuse the jet the pressure builds up inside and causes the carrier pipe to split and it can do so in 3 places, front centre or bak, firstly my bak secion went so got it all taped up to seal it, staight after i used it again the centre section went and its been fine since that got taped up
My rear section has just gone too. Repaired that but it has someware els now. gona have to pull the boot apart to fine it. Boo.
centre section sits at driver side rear of boot, fold seats down and take off seatbelt rear cover at driver side and behind the boot carpet lies the pipe, thats where mines split after i fixed the boot
