Warming up and cooling down...
Faisal
UK's 1st Liquid Yello LCR
May 27, 2008
1,445
Most likely at work
i mean coasting as in putting ur foot down on the clutch and holding it down (keeping the revs at 0)
iv heard this puts strain/pressure or something on the clutch...
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Revs at 0 means you have switched the engine off. This isn't particularly bad: some eco-cars have been designed to do this, (switch off when not needed) but they have bigger batteries and starters designed for frequent use - the intention is that when stopped in traffic the engine shuts down, restarting (first time, every time, of course...) when you put your foot back on the accelerator pedal to move away.
The problem with this practice is the temptation to restart the engine by letting the clutch out. The clutch is not designed to spin up a stopped engine, the speed mismatch is way too high, and it will wear out your clutch lining prematurely. If for some reason you are switching the engine off when the car is in motion, restart it with the starter motor, not the clutch.
Costing with the engine off and clutch in is bad, as it pumps unburned mixture into a cooling catalyst. This will kill the catalyst stone dead in short order.
I don't think either of these is what andycupra meant, though. By coasting in gear he meant foot off throttle - nothing more. The ECU will detect this and cut fuel injection to zero in most cases, which aids cooling down. This is better than coasting with the engine on but the clutch pressed down, because the ECU has to supply fuel to keep the engine ticking over
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
tbh mine seems to warm up even more if i sit on the drive and idle after a drive. no cold air flow i guess. on the subject of turbo timers, i think halfords do one for about 30 quid... any alternative suggestions... pros/cons. i'm sceptical of anything thats tinkering with ignition and so forth..
andycupra
status subject to change
alternative suggestion would be to take the last few miles of the journey easy thus removing the need for either you to sit parked up for for mins or fit a turbo timer which may: possibly invalidate insurance, get youprosecuted for leaving the car running while not in your control, or as you cant leave it in gear find your pride and joy has moved while you have been away due to the handbrake not holding it.
IMO you can enjoy your car but with a little forward planning (you know where you are driving to) you can avoid all this need for turbo timers and cooling down and can even save time and money.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
if your driving very hard like on a track and stop, the TT might look after your turbo but your brake discs will cool unevenly as the pad will trap heat, may even increase it whilst stationary. so its still best to cool everything down.
also you may get insurance issues:(
