i took the plunge and bought a set a couple of months back, but im not that impressed by them. i do a lot of motorway driving and find they lift off the screen, they are also hit and miss as to how well they shift the water.
Stupid question time now, so feel free to reply with a sarcy answer if you want![]()
Is it just the passenger side you have problems with? Which side do you have the 21" blade on?
I've just been outside to have a look at mine and they look like they sit higher up the windscreen than yours Beowulf.
I have about 1.5" between the blade and the plastic trim yours is fouling on. If it were lower it would definately be in the way.
It might be worth taking the arm off and moving it round a spline or two to get it out of the way if you want to stick with the aero blades.
Tim, did the blade lift off while you were going along, or was it just that it lost its' springiness?
I've only had mine a couple of weeks so I'll keep an eye on them and report back if there's a problem.
They used to lift while going along, the worst was on a motorway in the pooring rain. On every stroke they were jumping off the screen. The literly left the screen by about 2 or 3 cm and then came crashing back down. I couldn't see a thing.
The problem I had when i tried a set of these was that ever now and again the drivers blade would lift off the screen. For the first couple of weeks they were perfect, and I didn't have any problems. After about two months it got so bad it became dangerous. So I replaced them with a normal set of blades and everything was fine.
The ones I tried were Boosch I think. I would be intested to know if these ones are any better. Like I said it took a few months though before I saw the problem.
don't bother if u have a leon m8 they don't fit just tried to fit mine
they go on easy click and ya done but if u have the angled wiper on the passenger side they hit the plastic coveringbecause of the way the arm is bent
shame really they do wipe the widow screen quit good
does anyone want to buy them £15 lol![]()
no m8 got my of ebayLooking on that site mate, the driver/passenger set say 2 x 26" blades, did you get them maybee?
The individual ones are 18" and 21" ??
I've got a set of these on my Bora and they work perfectly. Did you get ones for a left hand drive instead? If yes, the aerofoil would be the wrong way around and cause the blade to lift at speed.
Tim, I've had the Bosch ones for over a year and have just ordered these Valeo ones. I'll post when I've sussed the difference.
