v5toledo
v5toledo
hi everyone ,got a squeak when I depress clutch on the wifes ibiza 2003 1.2 have sprayed wd40 everywhere but it is still there anyone have any ideas?
v5toledo
thanks for that could be ,hoping someone would answer saying it was a cable which is not visible to the naked eye
FR-Jack
I had a 97 polo and the clutch started creaking with that i thought the same as you and changed the cable. Which did help but i discovered with min that the actual part that engages with the clutch was creaking on the pivot point but it was quite hard to gain access as it was inside the housing!
Could just be the cable though? and cales arn't usually that hard to change!
SWANSWAY CUPRA Dealership
