Useful / Trivial Things You May Not Know About Your Leon . . .
Stegor
332
Found out by accident today that if you're in the Audio menu on the MFD you can change tracks on the CD using the up/down buttons on the right-hand side of the steering wheel.
This applies to the F/L model with the audio controls on the left-hand side of the steering wheel.
Now you can change tracks easily whether you're left or right handed. :)
Found out by accident today, if you don't press the middle peddle when approaching another stationary vehicle....
jibba_128
298
ive noticed a few things
my car alarm goes off if i bounce in the car when the doors are locked?
one time my car was locked and i pulled the door handle and the alarm went off, never happened since?? (alarms not broke)
also if i turn up audio fast on the steering wheel or head unit it keeps going down and i have to turn it like a million times to get to top volume, is this a dodgy connection? it happens with my steering wheel aswell so...
wuhseer
75
Worcestershire
Believe you can change the alarms sensitivity in the MFD settings somewhere.......
GrahamFR
Now AMG Powered
Dec 10, 2008
4,235
Barnsley or Burton
here's one for you, not useful just trivial. Noticed it with my PD and CR.
Say your on the motorway, set CC @ 70 and then reset your MFD and put it on Average speed, on both cars now it has stayed at 65 for many miles, just a fault with the calculation? or are the speedo's 5mph too high (would explain a few ppl's top speed figures :))
G.P
1,281
45
Worcestershire
Not strictly true. The hazards are only activated automatically if EBA (emergency brake assist) has kicked in, i.e. if you move your foot quickly from accelerator to brake and apply enough force for the car to think you're trying to perform an emergency stop. It'll apply full brake force until ABS kicks in to prevent the wheels locking up. Only experienced this once for real in my FR and it frightened me half to death, although it did probably prevent an accident... :blink:
If you trigger ABS without EBA, such as at a greasy/icy junction, the hazards won't come on.
This feature I think must only work when you come to a stop as I've never had the hazard on when on A/B roads into corners however, at some junction's/traffic lights (in the dry I might add) come to a stop and the hazards are on, way to sensitive.
Unless your car is set up differently to mine, I think you perhaps need to be easier on the brakes. I've never triggered EBA in my Ecomotive and only triggered it in my FR when I wanted a genuine emergency stop... :confused:
G.P
1,281
45
Worcestershire
Well perhaps, but I think I'll keep enjoying the car even through the hazards flash from time to time. . .
Hugo Nebula
290
Manchester
I think it's widely known that the speedometer will over-read the actual speed by about 5%.
The legal requirement is that it should not under-read the speed (so that you can't exceed the speed limit when it's showing that speed), and should not over-read the actual speed by more than 10% (not strictly true as there are variations at higher speeds). Most manufacturers will aim for a figure in the middle, so most speedos read at +5% of the actual speed.
As Graham suggests, I also suspect that manufacturers take advantage to make their cars appear faster. I'm sure these days they could make a speedo that comes closer to 100% accurate, but still prefer to have their cars appear to be quicker to 60mph than in reality. Try it against a sat-nav that shows your actual speed as determined by GPS. That will be accurate. It may be that the MFD average speed is the more accurate measure (and presumably is linked to the odometer).
This is why I pass people at speed cameras at about 10mph faster (when it's safe to do so, of course). Most people will slow down until the speed on their dial matches the speed limit, not realising that they are going at least 2-3mph under the limit. Add to that the threshold value for the camera is usually 10%+2mph over, then a camera on a 70mph limit road won't trigger at less than (77+2)+5%=83mph as shown on most speedos. Stick to 80mph on your speedo and you won't get a ticket.
/dev/null
1,652
101
In theory you can be done for doing 70.1 mph as speeding is an absolute offence. Those grace limits are just guidelines.
tonto
1,265
plymouth
im surprised my battery didnt die when i first found out i could do my window trick! . . .they were up and down like a frikkin yoyo!
richpaul
I have a 56 plate FR and this feature was disabled by default, had to enable it using VAGCOM.
Another tip is on the SAT NAV if youhold down setup for 30 seconds you get the secret setup menus. This depends on firmware (the newer ones need vagcom to enable this feature). You can see the speed in there and set up the speed dependent volume trigger levels and all sorts.
Redemption
1,771
Hampshire
Found out today if you leave the DSG box in Neutral (even with the handbrake on) it won't let you take the key out of the ignition when you switch the engine off.
To get the key out you have to stick it back into Park and switch the ignition back on and off again.
