Turning off ABS
ibiza_95
1.8T MK2 Conversion
my pedal keeps ''jamming'' its done it twice in about a month, it feels like theres a brick under it and it wont brake... not cool when your driving behind someone, figured if i just turned it off id be alright.
Does the ABS work all the time then? i mean in a sense that it works what ever pressure you apply to the brakes?
Dec 17, 2006
1,837
Bristol
It should only come on when it senses a wheel has locked, in which case it alters the pressure going to the brakes in order to stop the lock-up.
Sep 20, 2006
756
Birmingham
mine stays on most of the time ;)
Mine comes on and off alot. When it stays on, if i pump the brakes and then turn the car off and restart the ABS light normally goes off. I think it may have to do with the fatc that i bought the cheaper sensor (£6) rather than the original one(£32). Ive put it down to the cheapness of the sensor and dirt sitting on the sensor (at leats thats what i assume lol)
sambo19
sambo
Oct 20, 2006
104
worcester
i have no abs light atall even at ignition. any ideas whats goin on anyone??? got me mot next month and no abs is a failure. nightmare!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Yup,
1.6 8v 75bhp (I think). 312mm brakes, Cupra 20VT rims, Cupra Leather interior, -60mm FK's
To come... 2.0 16v conversion & 16v rear beam (sat in garage....)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
mines doing the same - ABS works fine and pedal pressure is fine first time but a right bitch after that takes loads of heaving to stop
push down and rev/start up and pedal sinks so servo is ok so looks like mine needs a master cylinder now :think:
