Turbo wistle when engines idle
Leon_MHX
Stealth TDi
Nov 6, 2008
163
Cheshire
As said above im getting faint turbo whistle after then cars been run (up to temp) then when i stop and let it idle for a few minutes i can hear it. Then if i rev the engine it will go then usually come back a couple of minutes later.
Im pretty sure its the turbo as you hear it stood at the rear of the car, from the exhaust. Im just wondering wether this is normal behaviour for the car?
P.S - Its a 2.0l TDI Leon mk2
Thanks.
air121005
1,609
Worcestershire
Thanks.
mine turbo whistles! they all do!
the pitch of the whistle should get higher as the revs do!;)
"comes back after a couple of minutes" :confused:, would have though it would return as soon as the engine settled :shrug:
Leon_MHX
Stealth TDi
Nov 6, 2008
163
Cheshire
Revs stay the same, but you hear nothing then you get a noise as if the turbo has just spun up.
I could be sat idling for about 2-3 mins then i hear it.
air121005
1,609
Worcestershire
seems odd it takes 2-3 mins though :confused:
maybe on idle, it takes a while for pressure to build up very gradually to a point where the whistle becomes audible :shrug:
i'm not familiar with the 2.0 Leon set up so couldn't be sure TBH
Leon_MHX
Stealth TDi
Nov 6, 2008
163
Cheshire
Hmm, it does seem similar. I dont really notice it when its cold, its more when ive been driving quite a bit and the engine is hot
benuk
271
UK
Yes, I assumed it was only when cold as that was when I would be outside the car with it running most. I have since noticed when cold and when hot, but I only notice it sometimes.
Leon_MHX
Stealth TDi
Nov 6, 2008
163
Cheshire
Im pretty sure its nothing serious anyway ive been noticing it for a month or two now, and the car still drives fine :)
benuk
271
UK
yeah its not a problem, seems to be quite common as quite a few people have said. Not everyone would notice it tho.
