TRAX @ Silver stone - are you going??
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
take the door card off you mite have water in there
if not you can have a good look round the electrical ;) i thought inside the manual there is a fuse layout
-J-cupra
71
best thing to do is check them all mate, try get ya hands on a power probe! but if it was a fuse i would of thought the prob was on more than one door! ill have a word with lad at work tomoz he worked on VAG until he moved to us! may be able to say straight away. i know if the door pin is faulty the light wont come on and it will also lock becouse it wont know the door has been opened! would start with that.
t32er
looked for the pin but i couldnt see it, where is it, i must say i didnt look too hard, i was wanting to get on with my sewing
t32er
i dont care say what you like, i will be bringing my cross stick to trax too...
Seat Gooner
A.K.A Mark
Feb 28, 2009
1,952
Wisbech
Fuse Layout
Fuse number: Amp
1. Engine / Engine Electronics 15
2. Engine / Engine Electronics 15
3. Engine Valves 10
4. Ignition Transformer 15
5. Automatic gearbox/ reverse
light / heated jets 20
6. Automatic gearbox 5
7. Injectors / Fuel pump 15
8. Lambda sensor 10
9. "S" signal * (see footer) 5
10. Control panel / Diagnostics /
Central locking alarm electronics 5
11. Horn / Heated Seats 20
12. Right hand main beam and
pilot light. 7,5
13. Left hand main beam 7,5
14. Right hand dipped beam / right
hand lamp adjuster 7,5
15. Left hand dipped beam / left
16. Right hand parking light 5
17. Left hand parking light 5
18. ABS / TCS / ESP 5
19. Fog light / Rear fog light 15
20. Brake lights 7,5
21. Hazard lights 15
22. Indicators 7,5
23. Windscreen washer and
pump / rear windscreen washer 15
24. Head lamp washer 20
25. Heated rear window 20
26. Control panel lighting /Control
panel display / Electric mirrors/
Dashboard lighting 5
27. Inside, boot lighting / Alarm
Siren 7,5
28. Lighter 10
29. Radio / CD 15
30. Heater 25
31. Number plate light 5
32. Engines central locking 30
Fuses above relay switchboard:
33. Electronic front windows 30
34. Sunroof 15
35. Electric font and / or rear
windows 20
36. Canvas Roof 20
37.Power socket in luggage
compartment 15
Fuse Box in the engine compartment on the battery:
Radiator Fan, 1st gear 30
ABS engine relay 30
ABS main relay 30
Metal fuses (These fuses should only be changed at a SEAT Official Service Centre)
Alternator 150
Onboard network 110
Radiator fan, 2nd, 3rd level 40
Engine distribution system 50
Glow plugs 50
Fuse colour code:
Beige 5amp
Brown 7.5amp
Red 10amp
Blue 15amp
Yellow 20amp
White 25amp
Green 30amp
