Trist
I'm am new to the 1.8 20v scene so I am learning as I go.
I have had cosworths and Rs turbos before so was used to them.
I got involved in the vag side of things when I bought a golf VR6 to run as a track car.
That was bought as a cheap project to just use on track days. Then it ended being bright orange, poly carb windows, flocked dash, cage, slick tyres, coilovers, engine rebuild with baffled sump lightened flywheel etc.
I started to look for more power for the golf and changing engines or super charging.
In the search I found this ibiza cupra.
Imperial blue. Had a damaged front wing and no interior. Ideal for turning to a track car.
The car is comely unknown to me. It had a larger front mount intercooler fitted be bore it had the Knock to the front which got damaged so it had a forge side mount fitted.
All I have for it is a rolling road graph from JKM with the front mount for 252bhp
I know it's got K03s turbo. Not sure what else is needed for the graph of 252?
When I tried to fit the new downpipe and decat I found that the last owner had snapped a stud from the exhaust housing do I had to remove the turbo and drill and tap that out.
A fun task!
Old intercooler
Down pipe
Work in progress to remove damaged wing and fit new intercooler. Didn't go with a very large one to still get cold air to it rather than behind inner wing but still let air get to the rad.
Turbo out and repaired.
Back together trying to fit intercooler behind bumper
A fun task!
Old intercooler
Down pipe
