Can anyone tell me the torque wrench settings for the driveshafts on a Leon 1.8t the ones that bolt to the gearbox and the hub nut. As I'm changing mine tomorrow if all goes well.
For the internal 12 point bolts at the driveshaft flange, its 40nm if you have the m8 headed bolts, and 80nm for the m10 bolts. My 51 plate Cupra has the m10 bolts.
For the driveshaft hub nut you'll need a 30 mm 12 point socket. This should be tightened to 300nm then slackened off and then retightened to 50nm.
See this thread for more info.
Hey Matt, what driveshaft you getting - genuine or ebay ones & how much???
I've read it was 200NM, slacken 180 degrees, re-tighten to 50nm + 60 degrees.
I'd look into it more though![]()
I've just fitted a new hub and torqued to 200nm, back 180 deg, torque 50nm + 60 deg and it is fine after 150 miles.
Bentley manual:
gives the tightening torques at
tighten to 200 nm and loosen 1/2 turn.
Turn wheel 180 degrees
Tighten Again with 50nm plus additional 60 degree turn.
Okay then, from the ELSAWIN manual, not some American manual
The spline bolts were okay to undo, just make sure the 12-point bit has a good fit in the head of the bolt before trying to undo it. I used a screwdriver in the slots of the disc to stop it from turning.
Is it LHS or RHS you're changing?
I'm doing both mate
