top mounts perrished
captin_urbis
Not a Member
Dec 2, 2008
452
Lancashire
yeah got all 4 top mounts have perrished. need some advice. how much is it for replacement rubbers or is it worth buying a lowering kit before i do??
stinkypete
174
Chesterfield
it's not that much - try GSF. Dealers are a lot more expensive. You'll need some spring compressors though (if you're doing it yourself).
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Don't need spring compressors, remove the one bolt on top and the shock and spring stays as one whole unit!
You wont be removing the plate that holds the spring in place
