tips on Forge Valve fitting?
chughes163
89
Oxford, UK
Hi,
Getting my car REVO'd on wednesday now - got a better deal by him doing that only....have ordered Forge valve (007p) from ebay and am gonna sorce green air filter separately.
How difficult is the Valve to fit? does anyone have any guides? Think i will attempt it on the evening i get it chipped!
Cheers [B)]
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
heres afitting guide in the forge section and on the forge motorsport website.its a direct replacement of the standard dv.
should use the search option!
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
The reason you probably had trouble finding anything when you searched is that there as so many threads on the topic. Most of them shouldn't have been started - and this is another one much the same. :)
chughes163
89
Oxford, UK
lol fair enough :) but shouldnt the search criteria be better then or maybe something in BOLD at the top of the leon thread? no ones fault really....i dont feel guilty! lol
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
The second larger one use clip was a pain in the arse - I had to just keep at it with a flathead screwdriver at first, then a pair of pliers. That was the only tricky bit the rest was sooooooo simple.
Cupraloon
Hi,
Cheers [B)]
Easy Peasy to fit, i did mine in about 30 minutes, you'll need some new hose clips 2 x 22-29mm and one at 10mm i think it is.
The hardest part is getting the old crimp type clips off..
Because of the cramped access to the larger clips I's recommend a srew driver with flexi shaft and socket bit, makes life much easier....
chughes163
89
Oxford, UK
thanks a lot for all the tips! got the car chipped yesterday.....lol had a problem with the software and it ended up taking them 3.5 hours! (was waiting for it to be done!) - they were very appologetic & they did me a custom code for the same price due to all the hassle! really impressed with the results. The forge valve arrived this morning so will fit it a bit later
