TIP Fitting mucked up
b_wain
118
so what do you gain from fitting a new TIP?
Im an idiot before any one comments :D
b_wain
118
so do you think you would notice the diference? power and any change in tone?
benjiwales
benji
Jan 29, 2007
297
Penybont
Deffinatley notice the sound difference, as for the change in power, well its more about the turbo coming in quicker, it's difficult for me to say as the day after I fitted mine I had the car remapped
jamiebennett81
main difference is the pipe replaces the metal restrictive turbo tip which goes onto the turbo
the forge tip effectively stays the same diameter from the induction kit all the way to the turbo, instead of a bottle neck type effect which is what the standard setup offers
main advantages are quicker spool up, but allowing the peak power to be held for slightly longer when mapped due to increased air flow
I have it on mine, but to be honest you wont notice a massive amount of difference in the cars standard form, it comes more into play when the car has been remapped as of course the boost is vastly increased
jamiebennett81
edit my last comments, through some logging I have been told of, the increased air flow lower down the rev range with the tip fitted is alot higher than over standard
my bad, it does make a significant difference on a standard car
