Looks good mate
Charge pipe and manifold would look good gloss black
I planned to do them satin black. Black silcone hoses and get the s3 side engine cover fitted in gloss White with all bottles black with White lids.
However had a really annoying knocking noise, from NSF.
So far replaced Top mount bush and bearing, NS drop link and Both Rear wishbone bushes for poly ones.
Had Gearbox mount out, checked every bolt on the strut, calliper, carrier, checked dogbone bush, ARB bushes. steering rack bushes, track rods, dash bolts, had glovebox out, pollen filter housing etc etc! Its doing my head in, Shocks not leaking but wouldnt mind locating one to try.
Wow this car is awesome mate! Shame I havent seen this around norwich! Would love to see what the custom Jabba map is like...i've currently got jabba's generic stage 1 map.
Its a nightmare isnt it! Ill find it one day... Tightened door hinges and removed glovebox, secured everything behind it, and it went for a day... now come back!Let me know what it is when you find it, I have the same on mine and have replaced virtually the same stuff as yourself
Hi Tim finally signed up! Are you sure its not your brain rattling about? I've had a horrible knock/clunck when setting off, braking and over bumps. Disconnected ARB now noise gone!
