throtle body question
crazy-steff
hey all, was wonderin if any1 knows what causes a throtle body 2 need realining?
cheers
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
this is because the trottle body are control by motor NOT by wire!. So you cant adjust them manualy!
when new trottle is added or a old one cleaned it may get out of liine. so when you reconnect it will adjust to the right setting!
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
dissconnecting battery would mean it gets realigned...
only if you allow it to surely. For instance you have to wait for it to be realigned before starting the engine, i thought that if you just turned the engine straight on without waiting a minute or so it wudnt be aligned correctly
Big_daddy
Oct 20, 2006
3,930
Brummy
iif you dont let it align , you need to disconnect the battery again and reconnect. Then let align properly!
crazy-steff
cheers its just that i was getting idleing issues, and i got told 2 religne it.... at the moment it has sorted the proplem, was just wondering what would cause the throtle body 2 need realigning.....
andycupra
status subject to change
yes you are correct, when you realign it, ie dissconnect the battery, you need to reconnect, then leave ignition on with engine not running for a few mins to allow the realigning to be completed.
(if not sure 5 mins is plenty, but you may here a high pitched sound during realignement).
NOTE: this should be done on a COLD engine.
crazy-steff
Metals expand with heat, although only slightly. So re-aligning the TB when it is warm may cause it to be incorrectly positioned due to the expansion then shrinking as it cools.
ace top pice of info!!! will realign mine again because my engine was slightly warm when i did mine (temp sensor was on cold though) engine was warm 2 touch, would this make a diferance?
marshyc
299
Huddersfield
Probably would to a slight extent. Alot would depend on the metal the TB components are made of.
Best off doing it when it is cold (i.e. stood all night) then you know it is right. Not saying you will notice any difference but all the same best to do it right.
traumapat
Leon Cupra IHI
Jul 24, 2005
5,925
sunny sussex
cheers
theres proberly loads of reasons mate. tb`s can get gunky and stick. thus changing the size and operation. so its an ever changing part but vital to running and needs recalibrating.
going on the heat/cold expansion point.. i wonder if summer /winter temps affect that calibration???
