Techie is back Boca style
EdHorny
Loves his Boc.
Oct 12, 2008
453
Burntwood
Did anyone see the Lamborghini in Nuts mag this week, it had a black and white theme to it. Well I'm sorry but techie's Beast is miles ahead of that Lambo. To give you an idea, think Mercielago in black with white side skirt and wing plus 2 triangular white patches on the bonnett.
Not a patch on this man's effort's, hat's off to Ross.
ED
vroomtshh
4,222
Dreghorn, Scotland
I fitted them to my Fabia which is exactly the same no problems. What car where they off of? and what is the problem?
I know you did, that's why I was sure they would fit. They were off an LCR. The carrier needed spaced out 6mm and I then had to grind a little out of the carrier where it sits over the disc.
Your carriers look identical to mine. And that would suggest yours will need the same treatment. The mk4 carriers are a lot thicker where they connect t the hub
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
If you needed to space the carrier out you have four wheel drive carriers mate, pretty sure of that.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Octavia vRS rears on my Fabia (same as LCR)
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Mine are from an LCR, I know it as I was there...lol.
As I tried to fit some TT ones to my first Fabia I tried using the adapters for the MK4 Golf which are 6mm wide but the disc caught on the centre part of the carrier and locked up.
vroomtshh
4,222
Dreghorn, Scotland
That sounds right. I had to space them 6mm then had to remove some of the centre part of the carrier as the disc was catching it. They're fitted now so I guess it won't matter
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Yep they are four wheel drive carriers then 100%, mine just bolt straight up, no spacer or grinding.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Finished and ready to go on...
also might have bagged myself a set of 334mm R32 front brakes just to take the piss. Lol
HAIRWEGO
NICK...
Jan 18, 2010
781
Poole, Dorset.
just seen what you did, i went on my hols 2 weeks ago, you were just going to have roof done. and as i see now it is finished , it realy does look fantastic , you gotta be so proud of that motor . all the things you done, i thought oh ****, but then when i see it , this is great you make the right choice every time.
proberly not finised yet, i did'nt think so hehehehehe.................
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Thanks mate :)
Handle is now fitted, not 100% on it myself. Might do the spare handle black and compare.
Bur either way looks better than chrome.
