Surging / Holding Back On Acceleration
quattrojim
right so i will check all pipes first, then i can do the n249 bypass, hopefully that should solve the problem. thanks for the help!
mattfas
97
leeds
just updating thethread my car does the same like ive explained early on in the thread just had it on vagcom and its showing my maf been faulty giving this code p0102 signal too low but does anybody know how to clear the faults using the shareware version of vagcom
jonesy118
388
Cheshire
select control module
under basic functions, click 'fault codes'
once it's discovered some fault codes, click the button at the bottom (clear Codes -05)
quattrojim
my car now only seems to hold back sometimes, i can go for a drive and its spot on, other times its really slow and has no boost, am i right in thinking this is more MAF related?if it was a boost leak wouldn't it do it all the time?
Mattsthat
Sorry drag this up from the depths but my 1.8t is experiencing this sort of fault. If I got a scanner like the 30+ quid readers on ebay will this show as a fault and is the scanner actually any good?! Sorry can't post a link!
I've tried a obd2 code reader but that shows nothing........unless there is anyone localish to me that can help!?
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Look on shpock and Gumtree keyword vcds or vagcom and see who is around you for a quick and cheap diagnosis. Most charge £10/20 and will be more helpful than any dealer.
Vcds is what you want to buy if you're going to keep it. Will pay in the long run if you have no one about with it.
Sent from my Nexus 6 using Tapatalk
verbal_kint
639
31
North West Kent
And to move Andrewwright's advice along a bit...
if you get knowledgeable with it then you could be the guy in your area helping others out for a small fee.
