Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
just updating thethread my car does the same like ive explained early on in the thread just had it on vagcom and its showing my maf been faulty giving this code p0102 signal too low but does anybody know how to clear the faults using the shareware version of vagcom
select control module
under basic functions, click 'fault codes'
once it's discovered some fault codes, click the button at the bottom (clear Codes -05)
my car now only seems to hold back sometimes, i can go for a drive and its spot on, other times its really slow and has no boost, am i right in thinking this is more MAF related?if it was a boost leak wouldn't it do it all the time?
Sorry drag this up from the depths but my 1.8t is experiencing this sort of fault. If I got a scanner like the 30+ quid readers on ebay will this show as a fault and is the scanner actually any good?! Sorry can't post a link!
I've tried a obd2 code reader but that shows nothing........unless there is anyone localish to me that can help!?
Look on shpock and Gumtree keyword vcds or vagcom and see who is around you for a quick and cheap diagnosis. Most charge £10/20 and will be more helpful than any dealer.
Vcds is what you want to buy if you're going to keep it. Will pay in the long run if you have no one about with it.
