Stripped hex bolt on manifold
CupraChris1981
124
12
I have a welder and a Dremel, both seem like will be risky I'm inclined to try the small dremel first to see if the washer can somehow be cut out
Rich.T
1,609
932
Not sure this would work it looks like they are using it on posi/Phillips screws not rounded torq/hex
But the principle is the same.
Youve got nothing to lose by dipping the socket into grinding paste and having a go.
I used this tip a few years ago (cant remember weather it was bolt or screw) and it worked.
CupraChris1981
124
12
In the end I bought a new bolt remover kit and it worked a treat only had to cut off one head with the dremel, but now I have the problem of replacing the bolts, I have some TV mount bolts that would fit although are a bit longer, I need 6 of them for the inlet, would it be possible to use these instead?
MoToJoJo
823
653
Northants
Ok, because I like testing stuff, I know the temperature of the top of the inlet manifold during normal running. It's about 70°C fair to say the underside is a tad bit warmer.
Also, you're talking about alloy head and manifold.
My point is that this is a surprisingly harsh environment. Would those bolts work? Maybe. Is it a good idea? Not really.
As ever, just my opinion, tis your car to do with as you wish
Reactions: CupraChris1981
CupraChris1981
124
12
I didn't want to replace with the same bolts I took out as they were a nightmare, any links to similar bolts? I search for inlet manifold bolts and cannot find what I'm looking for
BigJase88
Jase
Apr 20, 2008
3,767
1,076
Do not use that bolt
You need to know tensile strength.
Some 8.8 tensile bolts should do you and that is called a cap screw. Measure the length of the threaded section that is your length in mm.
So you will be looking for a cap screw say M8 x 50 as an example.
You may even find they are 10.9 tensile.
Or just go to to SEAT and get them to order you them
CupraChris1981
124
12
Could these do the trick? The car is not driven much anyway I just needed the turbo fixed https://www.ebay.co.uk/itm/131029737166?hash=item1e81fb1ece:g:52IAAOxywXFSanYv
BigJase88
Jase
Apr 20, 2008
3,767
1,076
Cap screws like that yes however those you have posted are 12.9 tensile. They may be too brittle. With increased tensile strength you get a stronger bolt however they do become more brittle
My example of M8 x 50 was only an example.
Without having the cap screw in my hand i cannot tell you if it is M6, M8, M10 or what length.
You have the cap screw bolt you took out so you can measure the length.
It is probably an M6 or M8 but i cannot say without seeing it
CupraChris1981
124
12
They are 40mm m8s , i think one of the bolts is salvageable, what would you estimate the odds of the bolts snapping given the car is not driven much?
BigJase88
Jase
Apr 20, 2008
3,767
1,076
New bolts or the removal of the old ones?
Put some copper grease on the thread when re-assembling and that will do them. I doubt they will need to come out again if ever
Cupra con
Littleredrocketpd150
Feb 16, 2020
21
High Wycombe
That happened to me, and on the crankshaft pulley, all I did was clean any oil off the head and bang a 12mm straight over the top , it’s tight but you need to have perseverance and a big forearm lol
